メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
695回答 すべてを表示
Xbox One Won't Read Discs - Laser Stuck/Damaged?
I bought a used Xbox One recently and it was pretty filthy, and while it works fine, it refuses to read any disc in it, bluray and DVD.
I cleaned it out pretty thoroughly and scrubbed down the disc drive rollers which seems to have made it happy, and also gave the laser various q-tip baths, but it still will not acknowledge any disc.
It doesn't seem to be an issue of the disc not going in all the way since the drive will fully accept any disc and spins them.
When a disc is inserted the laser will move very gently and attempt to read it, then return back to the spindle and repeat. It doesn't move all the way to the edge of the disc - is it jammed, or is there another fault in it?
I took a video showing what happens:
I'm really at a loss here and can use some help - is it the laser? The array? Is it totally fried?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Seems like a fatal issue with the actual disc drive itself. The easiest option is to buy a new disc drive and replace the PCB on it with the old one. This does require soldering so your gonna need a soldering iron.
Here's a guide incase you want to try it: Xbox One Disc Drive PCB Replacement
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
OrangeAtlas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 61
