メインコンテンツにスキップ
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
542回答 すべてを表示
I got no output ive changed gpu,ram,motherboard,cpu
I turn my pc on fans are on, no output, ik the monitor works cause well I use it everyday, I've tried 2 GPU nothing, I see people write things like change start-up options but I cant do that as I cant see the screen, help???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi,
What is the make and model number the PC or the motherboard if a custom build?
can you get into BIOS with a display?
Changing the motherboard as well doesn't leave too many options except perhaps the PSU.
Try the paperclip test on the PSU and make sure that all the voltages are there and correct
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
My motherboard is a ASUS PRIME H610M-E DDR4 LGA1700 mATX Desktop Motherboard
My Psu worked in my main build then I took it out, left for about a month then started building this, I feel try the paperclip test tomorrow morning as Ill need to go buy paperclips, Ill inform you tomorrow morning, Thank you so much for your help
さんによる
@Axxul.
Initially I missed that you said that you changed the motherboard so it shouldn't be the problem. Sorry about that.
You only need the one paperclip or any metal wire that fits into the appropriate pin connections of the PSU motherboard power cable plug.
You'll need a digital multimeter though to read the voltages
さんによる
コメントを追加
回答を追加する
Axxul. さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 22
