メインコンテンツにスキップ
2022年2月25日に、Valveより発売された携帯型ゲームコンソール。
104回答 すべてを表示
Steam Deck fit toghether case parts
Hello everybody, I have a Steam Deck, where it seems that the front case and the back case doesn't fit perfectly together. This result in a clicking noise on the right side of the steam deck when holding it very tightly. The case doest seem to be very sturdy.
As the official support cannot offer help as its not a functionality issue I would like to repair it myself.
On what part cases do I have to focus when trying to fix that kind of problem. The spacers or isolation material?
Thanks you very much.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi
Here’s a full disassembly guide of the steam deck
Steam Deck フロントシェルの交換
As for what you should focus on ,I think it’s probably best to look into the shell/case as they have everything screw into them
If you follow the guide through and successfully reassemble the device you should hopefully have a steam deck that fits nicely together
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Thank you very much for your kind reply.
Unfortunately for me, it's too challenging removing the whole front panel.
But I was able to remove the back panel and reinstalled it. Now it seems a lot better. During gameplay when the device is heating up the parts still feels a little bit uneven but in cold state its way better than before.
Thank you very much
さんによる
@fhihu
Glad to hear it’s somewhat improved:-)
If it gets worse asking valve(again) might be a option
さんによる
Hello, MacOS,
This guy wrote in his review that the backplate doesnt fit nicely at his steam deck.
Steam Deck Back Plate
Maybe it only the backplate. If its getting worse I will contact steam support again.
Thank you
さんによる
@fhihu
It could be that the back plate is designed in such a way thats it’s difficult to get on and off
The person mentioned using electronics grease to help get it on properly
Doing something similar might be a option if it becomes a issue
It could also be worth looking for a 3rd party replacement part ,if you do this look at the reviews and check to see if people as saying anything similar:-)
さんによる
コメントを追加
回答を追加する
benji wankerman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 79
