メインコンテンツにスキップ
The Nexus One (also known as the HTC Passion and Android Dev Phone 3) is a smartphone from Google (manufactured by HTC) that runs the Android operating system.
19回答 すべてを表示
nexus one restart interval of 10 mint
my nexus one restart interval of 10mints,what can i do
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
What have you tried so far? did you try a reset? Checked your battery? Does it charge okay? Did this just start by itself or did anything happen to the phone?
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hi there. It seems to me that your issue is likely to be ROM related. Is your nexus one rooted? If so, are you running a custom ROM such as cyanogenmod?Random reboots are primarily attributed to ROM or kernel problems. Have you installed a custom kernel?
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I am having the a similar problem. But after extensive trouble shooting trying CM and few other roms I found the problem is hardware related.
With the nexus one switched on remove the battery cover, now but the phone facing towards you try pressing with your fingers just under the power button where the speaker is. Try pressing just around that area with your fingers around that area. You might find a spot where it will reboot every time you touch it.
このアンサーは役に立ちましたか?
スコア -1
コメントを追加
回答を追加する
Gaurav Kishore さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,034
