メインコンテンツにスキップ
2017年に発売されたAppleの第3世代スマートウォッチです。オプションで通信機能が付いています。
197回答 すべてを表示
Can Apple Watch series 1 LCD 42mm be used on Apple Watch series 3 42mm
Hi guys, random question which most likely has an answer of a big NO. Anyways, I have an apple watch series 1 at home which I broke the glass on a while back but the LCD still works fine. The other day I broke my series 3 and the LCD also failed annoyingly. I bought the new apple watch SE 2 but as I do some rough stuff at work id love to be able to use my series 3 so I wouldn't have to worry as much. I was wondering if I can use the LCD from series 1 to repair my series 3 and then buy the glass separately due to the full assembly being so expensive and not worth it. TIA
P.s both are only GPS if that makes a difference
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@gwion_davies sorry but that won't work. They are not compatible. Different connections, different layout etc.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Gwion Davies さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 13
今までの合計 76
