Well When I Put My Dyson To Charge It Doesn't Charge
I Think It Is Not Normal
@sebastianputura check the charger itself first. Make sure it is plugged in etc. Then check the connection between the Dyson and the charger. Make sure they connect properly and nothing is obstructing the charging port. After that, you may have to try a new battery.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 63
4 件のコメント
Hi
Do you get a light in the charger?
Also have you tried a different battery?
HelloMacOS さんによる
No I Don't get a light in the charger
Sebastian さんによる
No I haven't tried a different battery
Sebastian さんによる
@sebastianputura
Do you have a different battery or charger to try?
HelloMacOS さんによる
