メインコンテンツにスキップ
Xbox 360ラインの2013年中期に発売されたゲームコンソールです。4USB端子と組み込み式Wi-Fi接続が特長です。
89回答 すべてを表示
What steps should I take to check why my fan isn't working?
I have been dealing with the insufficient ventilation error, and noticed that the fan was not spinning at all. I did some testing and was able to confirm that the fan works when using an independent power source (9V) battery, but I would like a permanent solution to fix the power to fan issue. When I removed the motherboard I did find that there was some water damage (got this from facebook) and it was over the whole board. I have no idea what I should be checking to narrow down what would cause the issue, is there a diagram that can show me what on the board is related to powering the fan?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
I found these schematics on Google if it helps:
https://archive.org/details/Xbox_360_Xen...
Water damage can be very tricky. It wouldn't be a terrible idea to start by giving the motherboard a good cleaning, especially if everything else is working. Take plenty of pictures before doing so. Sometimes cleaning the board is a fix, but if it's not, having those pictures is a good reference point to troubleshoot further.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Doxx さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 47
