メインコンテンツにスキップ
ATX Mid Towers have the same general build and parts as other mid size computer towers
32回答 すべてを表示
I can't make windows recognize secure boot for windows 11. HELP!
Hello everyone. I've been trying all day to make my PC check all requirements of PC Health Check in order to be compatible with windows 11. Still the same problem. "This device must support Secure Boot"
Motherboard: Asrock B365 PRO4
current OS: Win 10
My OS driive is in GPT format
I have an installed Asrock TMP 2.0 as you can see on the picture below
I've watched tutorials on youtube and tried different things and still can't fix it.
I tried:
I updated the bios to the latest stable version, because it was written that it supports windows 11
I tried those things from the official site of the motherboard and from youtube tutorials
I am desperate, I Don't know what else to do! Can someone help me, please? I really want to install windows 11, and no, I don't want one of those hacked versions of windows from torrent sites.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Hi,
Assuming you have Win 10 installed, go to Control panel > Administrative Tools > System Information > System Summary.
In the right hand panel find "BIOS mode" and check what it shows.
It should show UEFI mode and not Legacy mode (or BIOS mode)
If it doesn't show UEFI then try going into BIOS > Exit > Load UEFI defaults.
This loads UEFI default values for all options.
I think that secure boot doesn't work when in BIOS mode (Legacy mode) it only works when in UEFI mode.
さんによる
It is legacy. I did load default uefi defaults. Re-enabled secure boot. System info still showing boot mode:legacy and that secure boot is not active/supported! Health check still doesnt recognize secure boot
https://ibb.co/6gQfMYS
I read on some forum to disable CSM but I did this yesterday and the computer didn't want to boot so I had to remove an re-insert the cmos battery to reset the BIOS.
さんによる
@stan0033 Yes the system was probably first set up with legacy and that causes problems for secure boot. Computers and Windows can be so fussy!
さんによる
コメントを追加
3件の回答
ベストアンサー
UPDATE: After some headaches I Followed a tutorial to convert my OS drive to GPT by going in Pre-OS CMD and typing some commands and now I have windows 11. Ah, the effort!
Update (10/31/2022)
Go to settings>updates and security>troubleshoot>restart. after erstart go to troubleshoot>CMD. after restart in CMD type mbr2gpt /validate, then mbr2gpt /convert. Done.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
It would be helpful for others if you posted the link to the tutorial you used.
さんによる
@aactech
Yes it might be useful if it was similar to what it shows in the link I posted in my answer below.
Cheers
さんによる
コメントを追加
最も参考になった回答
I have not experienced this particular problem but maybe try resetting BIOS/UEFI to default (remove CMOS battery and discharge with power off) and reset reconfiguration.
Advisable to record your current settings unless you know them very well.
This has helped me in the past with strange BIOS/UEFI corruption - especially after updating.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi @stan0033
Here's a link that may help. It explains why you may show UEFI in BIOS but Windows shows Legacy mode.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
stan0033 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 56
今までの合計 989
