メインコンテンツにスキップ
The Bose QuietComfort 35 II (Model Number: 789564-0020) are Bluetooth, noise cancelling headphones designed by Bose. The device comes with a USB charger and a Headphone jack cord, and is compatible with IOS and Android Bluetooth Devices.
13回答 すべてを表示
Bluetooth LED remains on even when powered off, drains battery.
As per title, the Bluetooth led remains on at all times, draining the battery. No other issues, bluetooth still works.
Any suggestions? I was thinking of simply desoldering the LED, but I'm not sure if the bluetooth reciever is remaining on, or just the LED...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
I have the same problem. I tried one of solutions on web which is disconnecting that long tape that goes from nearby to BT led to nearby on/off switch and while it resolves the issue with BT draining the battery, it also makes it impossible to charge the headset (which is a problem..) or use volume up/down buttons (which is not a big deal since I can control this using my phone)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
MICHAEL N ELCOATE さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 271
