メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
Why can’t I hear anything even though I have Bluetooth off?
My mother has an iPhone 6 Plus but she can’t hear anything and I turned off Bluetooth and still not hearing anything and I don’t know how to fix it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Dwight,
Check the headphone jack. It's designed to cut off the speaker when a headphone is plugged in, so if something has gotten stuck in there, it could be activating the speaker bypass. If there isn't anything in there, try a set of headphones or earbuds and see if you've got any sound there.
Also, is it the lower speaker or the earpiece speaker that you're not getting sound out of? They are completely separate pieces of hardware so it would be highly unusual for both of them to go out. You can check by making a phone call and having the other party talk or make noise. If you can hear them when you have the phone to your face, then the earpiece speaker is good; then try putting the call on speaker and see if you get sound from the lower speaker.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
You can also check the mute button is off.
さんによる
@imicrosoldering, Ah, thanks Chris; yeah, the silent switch on the side above the volume buttons. Almost forgot about that one!
さんによる
コメントを追加
回答を追加する
Dwight Raymundo さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 9
今までの合計 127
