メインコンテンツにスキップ
Microsoftが製造した、4K対応を特長とする高性能ゲームコンソール。モデルナンバー:1787
20回答 すべてを表示
Will this fan help or do harm?
https://www.amazon.com/gp/product/B07C78...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
@nytryder26 the issue is going to be that even if you install a fan, your airflow is just not there. You might even create more heat with it. You will have to modify the case to allow the air to pass through. If you are serious about making this work, I'd take the case to an automotive body shop (or sheet metal fabricators) and see if they can "punch" a couple of louvres in there. Then install the fan in a way that it pulls the air through instead of trying to blow on the circuit boards.
このアンサーは役に立ちましたか?
スコア 1
8 件のコメント:
You know the fan in the ps5, it has the same fan but it's blowing hot air at hot air bc Microsoft did not put a vent by the fan in this model. Who can I get to punch some holes in the plastic case?
さんによる
@nytryder26 any good fabricator can do that for you. Again I rely on body shops a lot for this type of mod. Even with plastics since they now deal with that now too.
さんによる
@oldturkey03 Ok, thanks for the response.
さんによる
@oldturkey03 Do you know any that I can search for?
さんによる
@nytryder26 what's your next bigger city ;-)
さんによる
3件以上のコメントを表示
コメントを追加
最も参考になった回答
you could try something like this and set the fan speed you want, https://www.ebay.co.uk/itm/191959658526
このアンサーは役に立ちましたか?
スコア 2
10 件のコメント:
Won't that kick me off of live?
さんによる
@nytryder26 its only a speed regulator
さんによる
@tech_ni I already opened and cleaned it, It gets so hot It doesn't work properly, now if the case is off it works better but I want the case on so how can I fix this?
さんによる
@nytryder26 did you change the thermal paste ?
さんによる
@tech_ni No, but I feel the heat on the heat sink so?
さんによる
5件以上のコメントを表示
コメントを追加
I'd go with the Amazon one. Doesn't involve opening the console and set it to auto and forget it. Beware the more cool air going in the more dust getting into the system too.
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
さんによる
@nytryder26 did you replace the thermal paste?
さんによる
@strongbow No, but I feel the heat on the heat sink so?
さんによる
@nytryder26 I'd replace it, it dries out over time. Helps take the heat away from the cup.
さんによる
@strongbow I touched it and its still moist
さんによる
コメントを追加
回答を追加する
NR26 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 13
今までの合計 198
