My Dyson works great when upright but doesn't suck well on the floor.
WHen It's upright the hose works fine, but when running (normal use) it seems to not have good vacuum. Is there a seal that's possibly broken? Where are the most common failures?
Hi @nixtechguy
Most of the time the bottom hose will have a issue if it’s not got suction when coming out of the upright position
Check the hose in the picture below
Check that it’s seated correctly and that there aren’t any cracks in
Also try not to let it go once it was been pulled out(pulls towards you to unlatch)as they can hide away if your not careful
It you cans see any let me know by commenting on my answer and we can further look into things
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 77
