メインコンテンツにスキップ
2.3L 4cyl or 3.0L V6, 6th Generation
428回答 すべてを表示
Window won't go up
My back driver side window won't go up.
It will go down using the driver and back switches but when putting it up, it will jolt/move slightly and then will make a slight sound and then nothing. It did go up once by pushing it up with my hands on the window but now it won't move past a certain point at all. When it was 'up/closed' before this, it never completely closed and would fall down slightly itself and I had to push it close with my hands on the glass.
Any suggestions? Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi @beccax,
Have you done diagnostics on this yet?
By the sound of it, the window mechanism sounds like it's either gummed up and needs a cleaning, or at worst in need of replacement.
You'd need to take off the door card (panel) and inspect what happens when you press the switch.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
@beccax besides the excellent answer by @geirandersen here are the parts of the SM that are showing you how to check the electrical parts 1998 2002 Honda Accord Power Windows of your power windows and how to get to the mechanical parts 1998 2002 Honda Accord Doors and work on them . I do agree this sounds like either a bad motor or a misaligned regulator.
さんによる
コメントを追加
回答を追加する
Becca さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 50
