メインコンテンツにスキップ
The Oculus Touch Controllers (2nd generation) are 6DOF virtual reality controllers used with cameras that track infrared light emitted from the tracking ring.
3回答 すべてを表示
Where to find and how to replace the infrared led array in the ring?
So whenever I was fixing a stuck button on my left controller i managed to tear one of the it sensors off on one side of the ring, just one. Now only the other half of the ring works. I tested this with my phone camera. I would like to know if anyone who comes by this post knows of any place that I could get a replacement infrared led set. Or replacement parts in general for the rift s controllers. I would buy a whole new controller but I don’t have very much trust for oem resellers. Unless anyone knows of a reputable reseller.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I did the same thing during disassembly while cleaning my Rift S controller joysticks. I ended up having to purchase a 10 pack of the correct IR SMD LEDs (part#:VSMB1940ITX01) and solder a new one in its place. Get in close with a camera and make sure there is still some solder pad remaining to stick it to before you take that project on. If you dare try this then get 10 of them. They are very small and pretty fragile so if your as unskilled as I am then your probably going to over heat the first 4 and crack them. I even cracked the 5th one a little on one corner but it still worked and has continued to for about a year now.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
water さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 40
今までの合計 371
