Why I turn to my phone to landscape mode my display touch is to week
When I turn to my phone landscape my display touch response is too weak
One of the best ideas I've seen for diagnosing touch screen problems is to bring up a drawing app, preferably one that will work full screen, and attempt to draw over the entire screen. The areas that aren't responding to touch won't be colored in so you'll get a visual idea of exactly what's not working.
In your case I would try it in both portrait and landscape mode and see if there's an actual difference.
Once you've done that, add pictures of the results to your question and we'll see what you've got there.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 213
5 件のコメント
@achukutty what exactly do you mean by "to weak"? Is it actually working or only in certain areas?
oldturkey03 さんによる
Display not working on certain areas
But I can play games with third party apps
Achu kutty007 さんによる
@achukutty is it always the same area that gives you trouble? Does that same area give you trouble in portrait mode? You have no problems with this in third party apps?
oldturkey03 さんによる
@oldturkey03 no only landscape mode
Yes no issues on third-party applications
Achu kutty007 さんによる
@achukutty if you have no issues when using third party apps it will not be hardware related. Check your settings and you may have to reinstall/update your firmware. I suggest you check sites like this one or on here
oldturkey03 さんによる
