Charging cord doesn't connect
When I plug it in to charge or connect to my car, the connection is very hard to get connected, I have to mess with it and set it just right or it won't connect. What can I do?
@treefarm if you find that the connector is actually damaged, you can replace the USB board (daughterboard). Something like this will work. Of course, check the connector coming from your charger first. Something like this video shows you how to get there. Careful on this model. The battery is glued in and a royal PITA to remove.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 154
