Convert incandescent bulb to LED
I will be as brief as possible. I use a mobility scooter, EWheels EW10. I only have 190 miles on the scooter. I have replaced the incandescent headlight twice. I would like to replace it with an LED. The current bulb is a bayonet type base(similar to the 1157 tail/brake light) with two filaments for high and low beam. The bulb is 12 volts, 35 watts. It is not much bigger than the 1157. It is a fairly large job to get to the bulb to replace it.
Can you give me a direction to go on?
Thank you
この質問は役に立ちましたか?
1件のコメント
That's a hard question to answer, Dave, without knowing the bulb type. Of course it's always possible there's an LED replacement available, but we'll have to know what it takes first. I looked around and had zero luck finding out what bulb fits your scooter.
Jerry Wheeler さんによる
