I have my acer laptop and I reset it but it doesn't start it only show
Starting problem after reset
Have you selected the proper boot device like Hdd for the first boot device? Unplug the LAN and flash drive it may try to boot from them. Your windows boot files are missing. That is the reason it is not starting.
These are some very common reasons that your system won't start. Most of the time boot files get missed after refreshing or resetting the windows. This happens when it connects with the files that are corrupted or virus infected.
To fix the issue you need a bootable flash drive or CD/DVD drive. You have to repair windows to start it again.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 114
@sjaglan this “ doesn't start it only show” needs more explanation. What do you mean by it only show. What does it show? What does it do? Why and how did you reset it? Restored the operating system?
oldturkey03 さんによる
@oldturkey03 it only shows choose boot options and when we select it restart again and shows the same options again
Sourabh さんによる
@sjaglan does your HDD or whatever boot drive you are selecting show up in your BIOS? It appears as if your OS is missing.
oldturkey03 さんによる
