Is this a screen cable related issue?
I have similar issue. Is this a screen cable related issue?
Often I seen this issue when the chin plate has been damaged. Basically the cables which sit just under it get damaged. These cables feed the LCD with the needed signals or the display its self received a physical blow so the bonding of the data cables have become dislodged.
Sadly, in either case the repair is the same replacement of the display assembly MacBook Pro 15" Retina (Late 2016-2017) Display Assembly and he's the guide MacBook Pro 15" Touch Bar 2017 スクリーンの交換
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 75
2 件のコメント
@vmv_86 - What is your exact system?
Different series had different causes.
Dan さんによる
@danj A1707 MBP 2017 15"
Vesa-Matti さんによる
