I need a dismanteling and rebuild informetion for this great nb
That small little cr 2032 inside has to been changed awfull to find, bad guys wich was mounting
Hi @itsmemarkus
The CMOS battery is on the underside of the motherboard. You will have to completely disassemble the laptop to remove the motherboard to get to the battery.
Here's an image from a dis-assembly video that will help you.
(click on image)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 63
1件のコメント
I'm not exactly sure what you are saying in this post, but what you are referring to is the Complementary Metal Oxide Semiconductor (CMOS) Battery. This is in charge of Real Time Clock, and often involves the Basic Input-Output System (BIOS) also. If your battery has died, just use a CR 2035, I have found often those work just the same.
9 9 9 さんによる
