メインコンテンツにスキップ
2019年3月に発売。Mac Pro (Early 2009)は、IntelのNehalemアーキテクチャをAppleのプロフェッショナルデスクトップラインに搭載し、2010と2012のCPUアップデートを加えて、インテリアが再設計されたモデルです。
181回答 すべてを表示
Mac Pro 4.1 flashed to 5.1
Hi guys, (@mayer)
I am wondering if I flash MP 4.1 to 5.1 what other "modifications" are need to get "full MP 5.1" ?
Is software/hardware support same for flashed 4.1 and 5.1 or there are any differences ?
Can I modified CPU heatsink from 4.1 so I will be able to use normal CPU and no de-lidded ?
Can I use normal CPU (no de-lidded) in MP 4.1 if I use water cooling ?
Anyone have any experiences with MP water cooling ?
Thanks a lot guys.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Watch this and then see if you have unanswered question:
https://www.youtube.com/watch?v=VrbnfYgg...
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
@mayer thanks a lot for the video :)
but he using "normal CPU" so are de-lidded CPU's only in MP 4.1 dual CPU ?
also can't read the spec on RAM's but I know that MP 5.1 support 1333MHz why he using 1066MHz ? (will MP 4.1 flashed to 5.1 support 1333MHz ?)
Thanks
さんによる
I remember that I has to use delided CPUs on the 2009 2.9 dual machines. I'm still using the 1066MHz RAM in both a 2009 & a 2010.
Here's a vid on the deluding:
https://www.youtube.com/watch?v=Et29f4uT...
さんによる
As a note, I used DodDudes method to upgrade to High Sierra and that PCIe SSD crashes about 3-4 times a day in both the 2009 & 2010 Mac Pros.
さんによる
@mayer isn't 2010 officially supported by High Sierra or you have to do this because PCIe SSD (mean DodDudes) ?
Well this is why I am so confused about de-lidded CPU's but if I check price for 2x de-lidded X5690 and dual CPU try for 5.1 it's almost same price :D
and what about SW/HW differences /support ? is there any for 5.1 and 4.1 flashed to 5.1 ?
さんによる
I did the DosDude upgrade on my 2009 2x 2.93. It was crashing, so moved the PCIe card with the SSD drive to the 2010 and it keeps crashing. Need to backup data, reformat drive and do the install on the 2010. BTW the 2009 processor board will not move to the 2010.
さんによる
コメントを追加
回答を追加する
Rob さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 16
今までの合計 66
