メインコンテンツにスキップ
Repair guides and support information for televisions manufactured by RCA.
181回答 すべてを表示
Can a RCA 50" LED LCD HDMI TV be fixed if it has a broken screen.
Can a RCA 50" LED LCD HDMI TV be fixed if it has a broken screen. TV turns on,but the screen is showing where it's cracked the screen and different colors. Is it repairable. Yes or no.
Thamk You.
Mr Bobby Joe Nunez
bobbynunez4216@gmail.com or 806-548-5272. If I don't answer please leave me a voicemail or text. My email is on here if you want to send me an email.
PS. Thanks Again.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @Bobby Nunez
Try searching for RCA (insert model number) screen to hopefully find a replacement screen.
Alternatively, disconnect the power to the TV and then remove the back cover and locate the screen make and model number which is usually on the back of the screen somewhere then search online using that information to hopefully locate one. TV screens are made by specialist manufacturers and not always by the maker of the TV
If you're lucky enough to find one, then don't be surprised that it can cost nearly half as much as a new TV.
If you can't find one or it is too expensive, an option to consider is to advertise the TV as RCA (insert model number) faulty screen - good for parts to try and recoup some of the cost towards a new TV. Working TV boards are always in demand.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Bobby Nunez さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 30
今までの合計 308
