メインコンテンツにスキップ
Microsoftの次世代4kゲームコンソールのXbox Series Xです。Xbox Series Xは対応コンソールと共に2020年11月10日に発売されました。
38回答 すべてを表示
HDMI pin 18 trace ripped
Hey I'm having trouble locating where pin/pad 18 connects to the circuit board, I have a pulled pad on the board 3rd from the last on the right I believe to be pad 18. I can't seem to find any videos where someone has had a similar problem. I just can't find where to run the trace to complete the circuit.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
its will go to both sides of that pad then
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
After further review I had told you the wrong pin it is actually number 17 the one to the direct left of the one pictured..I'm sorry for the mix up. If I'm thinking correctly it goes to the point above it but I still have no clue.
さんによる
Thank you so much the amount of research I done turned up nothing but this is gold...I do have one other follow up question I'm sure ik the answer already but I just wanna make sure that pin 19 connects to the one right above it? And pin 14 goes down to that diode or fuse? I'm not entirely sure I'm learning as I go lol
さんによる
@deathray01 yes thats right, you just follow the traces coming from the pad
さんによる
I'm sorry I keep asking questions but pin 14 does it matter if its connected to the diode or does it need to touch it I seen on some videos where they soldered it directly to that diode but never showed if they actually fixed it and I was curious if that was the correct way I'm sure it is being that there were a few who done it.
さんによる
@deathray01 they probably done that just to save them scraping the trace down to the copper so you can solder to the trace or diode it doesnt really matter
さんによる
コメントを追加
回答を追加する
Evan Wise さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 25
今までの合計 193
