Screen of my ipad is shaking
The screen of my ipad is shaking how can I fix hit?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント:
Do you mean the physical screen is loose or the display is jittering?
さんによる
What Arron said. If it the LCD is physically loose, you may have forgotten the 4 LCD screws that hold it in place. If you digitizer is loose, you may need to apply better adhesive to keep it in place. If the touchscreen is moving on its own, the digitizer may be defective, connectors are not fully connected, or the flex cable is pinched. This last one is probably a longshot but if you are referring to flickering, this may be a sign of a damaged LCD or static present. Charging the device to over 50% will typically get rid of any static present.
さんによる
remigiosunico what model iPad is this?
さんによる
コメントを追加
