メインコンテンツにスキップ
The Lexus IS is a compact executive car sold by Lexus since 1999. The IS was originally sold under the Toyota Altezza nameplate in Japan from 1998.
4回答 すべてを表示
Passenger air conditioning hot air drivers side cold air
Was told blend door actuator just not which actuator it is under dash
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Hi,
Which IS model, what year?
さんによる
コメントを追加
2件の回答
Try re-topping off the coolant.
First free up some internal volume/space by “burping” your vehicles cooling system aka getting the air bubbles that are trapped deep within pocketed traps making your cooling system run sporadic and overall inefficient.
You just remove the pressurized radiator cap when the car is completely cold, such as first thing in the morning after the car hasn’t been turned on since the day before. Remove the radiator cap, put your coolant burping funnel inside and somehow seal it at the joining of the two, add some identical color/type and preferably brand of coolant specified for your exact model of vehicle, and just fill it up like 1/4 the way, just enough to cover the opening so no vent to the open air exists.
Turn on your car and blast the heater while making sure the “A/C” button is on, yes while blasting it at max fan speed and with the heater engaged or max heat. Let it get up to temperature, expect 15-30 minutes of your car on, so if doing this in a regular homes garage, please make sure your garage door is open and there is an excess of free air and air flow.
Repeat the above in how you see fit but get creative with figuring out how to angle your car in a downwards slope or an incline to help remove awkwardly trapped (usually huge in size) air bubbles that could definitely cause a heater and or an air conditioner to not perform its best or sometimes not at all.
I am not saying this is the guaranteed resolution for this problem, but I do believe it is at least a 50% chance that it is. Worth looking into and or worth checking it out to research this “coolant burping procedure.
There are other possibilities but this to me is the one that stands out the most and for the KISS rule I’ll leave it at that. Best of luck, cheers.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Needs re gassed. Take it to get it done somewhere. System could also have a leak.
このアンサーは役に立ちましたか?
スコア -1
3 件のコメント:
If that somehow were the case then neither would blow cold. This is an actuator or door issue in the duct system. The fact one side blows cold tells me there is still refrigerant in the system.
さんによる
@brandon_k yes there is still refrigerant in the system but not enough. Best to have it tested by a professional.
さんによる
@strongbow I'm sorry but I have to disagree. Evaporator coils don't work like that. And the fact that the vents furthest away from the evaporator coil are the ones blowing cold means this is definitely not the issue. And that's my professional opinion as an HVAC/R tech. If it didn't have enough then the coil won't be able to cool or will freeze solid (if the LP switch fails to cut the compressor off). At best you'd feel a slight difference in temp in air closer to the evap but not further away. But it wouldn't feel cold. Would be a slight difference at best. The air coming through the evap comes in, goes through the coil, then comes out the other side where it is then directed to vents. It is one solid airflow that is then directed. The only way it is possible for it to be the charge would be if the ducting literally goes directly to the surface of the evap, and each vent has a separate duct. That's not how ac systems are made. Especially not in a vehicle.
さんによる
コメントを追加
回答を追加する
greenmds さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 25
過去 30 日: 55
今までの合計 328
