メインコンテンツにスキップ
長方形フォームファクタ/16GB容量/発表日は2012年9月12日
111回答 すべてを表示
My screen has a weird purplish tint on half of it and it is spreading.
My iPod Nano was in the bottom of my lunchbox with a few containers and a quite heavy water bottle. There was no water in the lunchbox and the water bottle was sealed very tight. For some reason, there is a purplish tint that started at the bottom corner but then spread to fill half the screen. I might upload a picture so everyone can see the damage. The screen and touchscreen still works and there is no visible damage to the glass but I would like to see if anyone knows what is going on and if it is repairable/replaceable.
Thanks for your help!
Diode
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
It sounds like the LCD has taken a hit from something heavy. This has caused damage to the LCD. Oddly, I can’t guarantee it will continue to get worse, I have seen some get better. However, the problem will most likely appear in the future. I’d get the screen replaced. If you feel confident enough, I have attached a link to a detailed guide with repair steps for this. The part itself can probably be picked up for around £10
iPod Nano第7世代 スクリーンの交換
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Hi @diode_cool
What might have happened is the connector for the battery/screen may have taken a hit and became loose
I would take it apart and see if the issue persists and if it’s still there replace the display as it could be internally damaged
If you do attempt this repair please get youse self some liquid and tape adhesive as that’s basically what these 7th gen nanos are made off
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Thank you! I will try that!
さんによる
@diode_cool
I hope all goes well for you
I recommend following this guide
As these iPod aren’t the easiest things to open:-)
さんによる
@hellomacos Awesome. Thank you for all your help.
さんによる
@diode_cool
Your most welcome
If you need anything else please ask:-)
さんによる
コメントを追加
Troubleshooting iPods Is Easy With The Five R’s
Reset your iPod by turning it off and on.
Retry the connection to your computer with a different port or cable.
Restart your computer and try everything again.
Reinstall the latest software updates on your iPod or computer.
Restore your iPod to factory settings, erasing all the content from it.
Greeting,
Rachel Gomez
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It is a screen issue though.
さんによる
コメントを追加
回答を追加する
DiodeInc さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 75
