Dryer will not heat
My dryer will not heat.
if everything else appears to work then you have either a faulty heater element, thermostat, thermal cutoff or perhaps the thermal fuse has been tripped.
I believe this unit is a re-badged Whirlpool unit. THIS MANUAL may assist - specifically 4-7 Thermal Fuse and 4-10 Heater, Thermostat, Thermal cutoff
This USER GUIDE may also help
このアンサーは役に立ちましたか?
MY WHIRLPOOL DRYER Model #LER8648LWO WILL NOT HEAT. i HAVE HAD THE HEATER ELEMENT, THERMOSTATE AND THERMAL CUTOFF TESTED AND THEY SHOW ok. what do i do next
このアンサーは役に立ちましたか?
check lint screen, no heat
check lint screen light is on. the dryer dose not dry the clothes
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,652
