There's a oil leak near and why do I hear Brake sound when I'm using
There was a oil leak from right front tire but there's no smell from oil, somewhere I feel like it's break oil. When I'm trying to press the break, I hear the sound like closing the old door, I've recently observed. Need assistance please help!
Hi @saikumar16,
Check the level of the brake fluid in the master brake fluid cylinder is the correct level.
If not you may be losing fluid from the front wheel brake cylinder
jayeff さんによる
Also get under there and do a visual inspection. Have someone press the brake pedal while watching it, and see where you are leaking fluid from.
brandon k さんによる
