Where to find a iPhone se 3rd gen (2022) compatible Battery
My battery health is bad and doesn't hold juice very good I need a 2018 mah battery not the iphone se 2 compatible battery which has 1821 mah ,thanks.
I realize this doesn’t really answer your question, but nevertheless. If you have a 2022 model SE, your device is certainly under warranty as they haven’t even been out a year yet.
If it says your battery health is Service, as it seems to imply in your post, that would be a warranty issue. Rather than replacing it with a higher capacity battery, I suspect your battery is just defective and a functional battery would set you right.
このアンサーは役に立ちましたか?
Amazon is where I get mine from. Couldn’t tell you the best on there but I know Yontex is a good brand.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 125
1件のコメント
What is the battery health at? And do you still have AppleCare?
Duck さんによる
