メインコンテンツにスキップ
Repair information for the SteelSeries Arctis Pro wireless headphones. Released in March of 2018. Model number: 61743.
58回答 すべてを表示
Can I fix my wire inside the headphones?
My right earphone on my arctis pro wireless has been acting very lose recently, and I kept twisting on it so that it would stop going lose. I didn’t realise that the wire inside was being twisted as I spin around the earphone, and now my earphone fell off. Can I replace the wire inside manually or do I need to send this to the shops to fix?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
If you are familiar with disassembling/reassembling things, small gauge wiring repairs and soldering, damage may be repairable with no guarantee of success.
さんによる
Vorceful add some pictures of what this all looks like, with your QUESTION. That way we can see what you see iFixitでの質問に画像を追加する方法
さんによる
コメントを追加
1 件の回答
最も参考になった回答
It's certainly plausible to repair. It will probably require some disassembly and depending on where the break in the cable is, soldering is likely the sturdiest method of repair. Wires in headphones are often a pretty small gauge, which makes repair more difficult. But not impossible.
Pictures would help assist with the specifics, you can add some into your original post.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Vorceful さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 13
今までの合計 347
