メインコンテンツにスキップ
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
153回答 すべてを表示
How do I replace the instrument cluster lights.
I have been trying to replace my instrument cluster lights. I have watched many videos and looked all over trying to find out how for my specific vehicle. I can remove the cluster but then the circuit board has one light bulb on it that indicates the head lights. Please help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Hi,
What is the specific Altima model and year of your vehicle?
Have you checked for small smd LEDs on the board?
さんによる
コメントを追加
2件の回答
normally the bulbs are very small and they are socketed.
If you have the cluster out, you should be able to drill down, removing the PCBs till you can see and remove/replace the bulbs.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I just ran into this issue as well I tore the entire unit apart on my 2006 nissan altima s with 2.5l to find out the lights are non serviceable led bulbs soldered to the cluster board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
John Lemon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 418
