メインコンテンツにスキップ
The Samsung NX2000 is a digital smart camera with a detachable external flash that was released in late 2013.
11回答 すべてを表示
Why isn't my Samsung NX2000 connecting to my computer?
I haven't used my Samsung NX2000 in a couple of years but i recently went to a wedding and took some pictures. Now I want to transfer those photos to my computer but it's not working, it's not showing up when i connect it with a USB. I have windows 11 so I don't know if that's the problem.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hi @m1t8
Have you tried a different known working compatible USB cable?
Have you checked in Win Explorer (Win Key + e key - both together) to see if the camera appears there, you didn't specify?
さんによる
@jayeff
I've tried different USB cables and it didn't show up when I checked in Win Explorer. Also checked to see if my USB drivers needed updating but that wasn't it either.
さんによる
コメントを追加
1 件の回答
選択されたソリューション
Hi @m1t8,
It may be that the USB controller in the camera has a problem and that it is not communicating with the PC.
At the very least it should show as a new USB drive in Windows Explorer.
If you need the pictures in a hurry perhaps try connecting the camera to your WiFi (WLAN) network (if you have one) and then send the pictures to your email address (see p.125 of the user manual)
Alternatively, remove the SD card from the camera and insert it in a USB card reader and attach that to your PC. If you haven't got a card reader already, search online for USB card reader to find suppliers that suit you.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Mathilda Andersson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 212
