メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
Headphone jack doesn't work and volume buttons dont function?
Hi guys,
I bought an iPhone 3G (old but not bad) off craigslist the other day. The guy said that the volume button was "intermittent"
Turns out that the volume buttons "click" perfectly, but don't do anything. The loudspeaker and ear-speaker work pr erfectly but can't be controlled by the volume buttons. The vibrate button doesn't work either but vibrations work.
I have been planning to buy a Headphone Jack assembly, will that fix it? I have an agenda to fix the digitizer/lcd screen and the headphone assembly.
Does it take too much more effort to replace the rear plastic case if I've already opened the iPhone to the headphone jack assembly?
Thanks a lot!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
open the phone and check the connector from the headphone jack assembly - sometimes it's not properly seated.
but it could be damaged too
i would check the resistors near the connector on the logicboard - had a few phones with broken resistors! (would that check before you order a new assembly)
replacing the plastic case is easy if you already stripped almost everything - but as i mentioned earlier - try to get it fixed first and then order parts - they are too expensive - especially when the rest wont work....
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I have the tools necessary except a suction cup :(.
Can I just use duct tape?
Also, parts are only around 4$ shipped on amazon... But I'll check before I buy - Buy in haste, repent at leisure.
さんによる
duct tape is not the best idea -removing that sticky stuff is no fun at all - you can also use a "household" suction cup (many different types are used in the kitchen or bathroom)
さんによる
コメントを追加
回答を追加する
souleben さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,451
