What washers to use?
Hi, I want to upgrade to a Xeon x5670,
I was told I need a spacer (2-3 mm maybe)
I can't find the washers.
Thanks! :-)
この質問は役に立ちましたか?
Thanks! :-)
この質問は役に立ちましたか?
Hi @beanman56
Here’s a US link for some 2.5mm washers
https://www.ebay.com/itm/112485217622?_u...
UK link
https://www.ebay.co.uk/itm/383536842495?...
I don’t know where you are in the world but these are the 2 most common place I know of
If you live out side of these place let me know and il find you some one from a different place
Hopefully this helps
このアンサーは役に立ちましたか?
@hellomacos - Now i will upgrade to the Xeon x5670,
Thanks, Also do think this listing is good? https://www.ebay.com/itm/275378766660?ha...
Seems good
Did you consider the X5675?
They are also quite good on performance
I have them in my Mac Pro
@hellomacos - I thought the X5670 is about the same as the x5675,
Is this listing legit?
Seems to be legit
It’s really up to you if you want to save some money as the only real difference is the clockspeed
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 203
