How do I get into my iPod touch
My son changed the pass code on my I pod and has no clue what it is. I can't get it open. Need help, Thanks.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
you will need to restore the software on the iPod - note the contents of the iPod will be deleted, your songs/movies/apps can be reloaded from iTunes on your computer later by re-syncing
if you connect the iPod to the computer which you originally synced with iTunes, you should be able to simply press the Restore button in iTunes.
but if you don't have access to the computer originally synced with this iPod, you will have to force the iPod into recover mode, then restore the software. Instructions to do so are here
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,341
