メインコンテンツにスキップ
2021年10月発売。モデル番号はGLUOGとG8VOUで識別。
57回答 すべてを表示
After screen replacement, there's one partial column of green pixels.
So I just replaced the screen on my Pixel 6 Pro with official parts from here. I tried to be very careful with the flexible PCB while reconnecting, but I guess I wasn't careful enough? There's a small column of solid green pixels at the top.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi
The flexible PCB you were taking about shouldnt break easy and along as you weren't too rough with it it probably wasn't your fault
I would try a OLED stuck pixel fixer video on YouTube just don't look at it and make sure nobody looks at it as it isn't good for your eyes or people who suffer from sensitivity to flashing lights and images, also make sure you let it run for a good amount of time
if that doent work try cleaning the connectors with isopropyl alcohol to remove dirt we can't see
and last but not least if all this doesnt work would contact google and ask them for some replacement parts because your OLED may be damaged internally
hopefully this helps
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jorsher さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 153
