iPod will not Power on after screen replacement?
My daughter recently cracked the screen on her IPOD Touch 4G. I decided to try to replace it myself and ordered the suggested parts. After following the instructions and doing the install the IPOD will not power on. I opened it up and checked everything and it mostly looks good.
There is one part looks to be ripped. I am not sure what it is called but it looks like it might be a ribbon cable of some sort. The part can be seen here
iPod Touch 4th Generation Front Panel Replacement
On the picture for step 10. The part is the yellow “ribbon” that connects to the circuit board just above the left top corner of the battery in the picture.
The “ribbon” ripped clean in the middle. Is this the reason I cannot power on my IPOD? If not, what other part might be causing the problem? Also, the “ribbon” that I ripped, is it fixable/replaceable? If so can you provide me instructions or a link to instructions.
Thank you so much!
この質問は役に立ちましたか?
