メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
日本の電子機器メーカーであるHitachi(日立製作所)のテレビに関する修理ガイドおよび修理情報です。
Can I use a t-con device with a slightly different model number?
I have a HITACHI 58HK6100U A 2012 and I'm pretty sure the t-con is fried.
I have looked everywhere for the exact model but the best one I can come across is one for the HITACHI 58HK6100U A 2010.
It shares the same part number "CCPD-TC575-009 V1.0"
https://www.tvparts.co.uk/ccpd-tc575-009...
Thanks in advance.
Update (06/29/2022)
画像
First off sorry for the slow replies, right in the middle of a house move,
the video attached is the only thing show upon switching on the device the other is a picture of the t-con board.
hope this helps.
many thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Hello mate did you try it in the end did it work because I have the same problem
さんによる 共有
コメントを追加
1 件の回答
最も参考になった回答
Jammy if it carries the same part number it might just work. The issues with some of the boards is that version numbers at times matter. There may be enough of a change for it to not work. I would at least give it a try. If you can let us know the exact number from your original board and include the Ver. number. Also, what symptoms is your TV displaying.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Apologies for the slow reply, I have updated the information with the things you asked for, thanks
さんによる 共有
Jammy could be a T-con error.....if it is not consider replacing the main board :-) YOur T-con in a 1.0 version so let me see if I can find out the difference between v 1.0 and others. Go for it and see if you can work out a return if this one should not work.
さんによる 共有
Hello mate did you try it in the end with a different T con board could I have the same problem and would like to know if it worked
Thanks take care
さんによる 共有
コメントを追加
回答を追加する
Jammy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 25
今までの合計 2,801
