Why the tv black?
The tv working but black all
Habeeb Khameis we need more information from you. First we need to know the exact model number for your TV. In general, when your TV is with a dark screen but you have sound, shine a flashlight at an angle against the screen. Let us know if you can make out silhouettes etc. If so it’s your backlight. If not, then you want to go ahead and disconnect all the video inputs and the power outlet. Then hold the power button down for 30-60 seconds. Connect one video source and the power plug. Then try and see if it restarts. Try all the video input sources as well. If that does not yield any change, it may be time to remove the back from your TV and take a look at the boards for any obviously damaged components. Post some images of your boards with your question. That way we can see what you see. Adding images to an existing question - iFixit Repair Guide
TCL is known to have inferior backlight strips.
このアンサーは役に立ちましたか?
I know this isn't fully Answer related by I just noticed you've hit 700K reputation!!!
I would just like to say well done and thanks on behalf of everyone here for all the amazing help and work you have provided us over the years!
Congratulations and keep up the amazing work!!! :-)
@hellomacos well thank you and I appreciate that.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 39
What is there model of your TV? Is there sound? Is there a power light? Is there a backlight?
Andrew S さんによる
Hi Habeeb Khameis,
The questions @andrewsawesome asks are crucial information.
Have a look at this: How to ask a good question
The more information and detail you provide, the easier it is to help :)
Geir Ove Andersen さんによる
