メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1199回答 すべてを表示
iPhone overheating when turning on
My iphone X was spilled with cooking oil 5 days ago. I dried it immediately. My only concern is the earpiece slot. I think the oil might be absorb in that area. I can't use it since when turning it on, the part around the power button, below the camera at the back is overheating almost immediately after turning on. What might be the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @pepperkaye
The phone is only water resistant and not waterproof. The oil may have got into the phone somehow and is causing the problem.
The impurities in the oil (all liquids) causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and any liquid residue. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that in general describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the oil may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit iPhone X guide that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kaye C さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 27
