メインコンテンツにスキップ
The Dyson V8 Animal is a cordless vacuum equipped with powerful suction that can last up 40 minutes on one charge.
12回答 すべてを表示
Dyson V15 doesn't hold charge overnight (tried two batteries)
So I charge the dyson and it works fine whilst im using it now if I put it down overnight (not in the cradle) it is dead come morning. If I disconnect the battery and put it back the next day its fine. So its like there is a short or something? Any ideas. I have got a free new extra battery to the same effect from Dyson
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi
iv seen this a couple times online and me personally would see if Dyson will replace your unit as Dyson handheld vacuums are not made to be taken apart at all(on the motor housing side that is)
if you really wanted to you could get it but would cause severe damage to the device in the process!
if its a v15 its fairly new so just in case I would let Dyson deal with it as if you take it apart they might void your warranty
sorry there isn't much of a solution
but I hope all goes well for you
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Same issue with my v15. Did you find a solution
さんによる
コメントを追加
回答を追加する
Ashley Towers さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 264
