メインコンテンツにスキップ
Released March 2019, identified by model number SM-A305FZRFINS
90回答 すべてを表示
It's not power on
It is unable to switch on the phone
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
We would need more information about what has happened.
- Has the phone been damaged (drop / liquid)
- Has it been repaired and now it's failing
- What have you tried
- Did it just turn off and now wont turn back on
The more information you provide, the easier it is to help you!
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Galli Boy Naresh besides the excellent request for more information by @geirandersen you need to start assessing this symptomatically. Check the charger first, then the charging cable. After that check the charging port. Attach an USB Ammeter to see if your phone even makes any effort to charge. If that works, you need to check and possible change the battery. Of course, you can also try reset (use instructions from places like this or even a factory restore (instructions on same site (YOU WILL LOSE YOUR DATA)). If none of that works, follow the Samsung Troubleshooting flowchart. You are now getting to the board level of your phone. You will need the tools and skills to check some really small parts :-)
Since there are various models for your phone you will need this file Board Layout. Use your PDF reader to search for the part location on your board based on the flowchart.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Galli Boy Naresh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 165
