Ripped logicbaord pad can't find a trace to run jumper
Hi
the board number is 820-00850-A and its the 4 thunderbolt 3 model
I was working on a water damaged MacBooks logicboard and noticed a component has fallen off
it took the pad with it and I can't find a trace to run a jumper from .
am I right in believing that I can run a jumper from c7214 to c7215? or does the number on the component not mean anything, if it helps they are right beside each other on the board diagram.
there 2 components are on opposites sides of the board to each other and I can find a via to start with
hopefully someone can point me in the right direction
any answers are greatly appreciated
@hellomacos if it is pad 2 connect that to common ground of either C7213 or C7215 pad 1 I‘d use C7215 but You will still need to use the capacitor from C7214 (do not apply a jumper instead) you just Bridge the trace not the component.
oldturkey03 さんによる
Iv added a photo of the pad i think is ripped(it’s the one highlighted in red ,it won’t really take any solder)
So just to confirm ,I run a jumper from the side of c7213 that’s connected to PPBUS_HS_CPU to C7214 and use the ground that is already there
HelloMacOS さんによる
@hellomacos that is correct. Use pad 1to pad 1 of c7214 and 2 to ground
oldturkey03 さんによる
Thanks!!!:-)
HelloMacOS さんによる
@hellomacos you are good with this? You got this.....! :-)
oldturkey03 さんによる
1以上のコメントを表示
