I can't charge my battery how can I fix?
I can't charge my battery how can i fix that? (The charge still work well)
Usually it is not the issue with the battery or the charge port if charging suddenly fails, maybe it's something on the board, the charge switch transistor for example.
このアンサーは役に立ちましたか?
Well I will suggest you to change the battery of your mobile phone or check the charger of the mobile.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 31
