メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Beats Solo3ヘッドホンのサポート並びに修理ガイド
rubber strip falling off the headband, need glue
so i wanted to fix my beats solo3 headphones so i peeled back too much of the headband, or actually so much of it and now its just flopping around and it just looks weird. can yall recommend me some good glues cause atm i have it held together using velcro cable management strips which while it gives the headphone this aesthetic, those strips will get dirty fast if i ever leave home with them. so if you guys have any quick setting glues with those precision needle tips you guys stand by and like can you recommend me that? i tried stuff like gorilla glue but the strip always just comes right off before the glue even sets, and i havent even touched the strap. or if you guys feel like i should just staple the rubber straight on, guess im looking for staplers lol
i swear, things got way worse when i was tryna glue the whole thing. initially it was only the areas around the hinges or whatever but the gorilla glue tip was too thicc to reach inside and glue my stuff so just reglue the entire thing. the red rubber shouldnt even be visible like this.
so i just use this manky jig here to hold the rubber and not have it slide off the headband. i like the way it blocks the beats logo so if i get this glued up i might be getting elec tape to cover up the thing.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント
Hi
Can you provide me with some photos as I work on beats products and you might not need glue
Follow this tutorial to add photos!
iFixitでの質問に画像を追加する方法
さんによる
i put pic for u
さんによる
Is it the bit on the left side of the image?
さんによる
I'd try contact cement. Apply to both surfaces, wait for it to get tacky before approximating them, then wrap with string, wire or rubber bands. Let it cure overnight... should hold. If you want to cover the logo get a length of battery shrink fit (heat shrink tubing on steroids) and shrink it all up...
さんによる
Iv tried that and it didn’t work very well
I don’t think it works well because I think the headband is silicon and I am yet to find a glue/adhesive that will constantly stick
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
Hi
The best way of giving this is by dismantling the headband
if you need help with it I can help you step by stem if you want
It’s fairly easy to do it,In Your case you just need to take the silicone headband off and move the white midframe back under then clip it back to the plastic part of the headband
Like I said it’s fairly easy and if you need any help give me a shout
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Hey I need help I just bought these white beat solo 3 headphones and they are doing the same thing I don’t know why , can u repeat by inna different way . I’m a slow learner
さんによる
コメントを追加
回答を追加する
MISSINGNO さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 64
今までの合計 2,882
