when I'm shooting the pictures comes black
I have problem when I take pictures pictures are black the old ones are fine and I can see all settings on LCD but when I'm shooting the pictures comes black the camera is coolpix b700
Hi,
Can you also see the images of the picture that you want to take on the LCD screen as well as the settings?
If not it may be a faulty image sensor (supplier example only) or perhaps a faulty motherboard.
Here's the ifixit Nikon Coolpix B700 repair guides that may help.
このアンサーは役に立ちましたか?
Strike around the lens barrel with a solid object. A small hammer, butterknife, or anything similar. You can even try using your hand. It sounds extreme, but this can work. I have had this problem. Even though the camera was always treated well, one day there was no image from the lens. Tapping around the lens can fix this. This problem comes with age of the camera as the lubricants get stiffer. If you check on YouTube "B700 repair" there is at least one video of a gentleman who had the same problem on a slightly different Nikon model. I had to hit my lens barrel more sharply and not as gently as he did but you will get the idea. Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 24
今までの合計 201
