My phone Bluetooth doesn't work when I put my phone in my pocket
weak Bluetooth connection within a short distance
Hi,
Does the WiFi work OK?
If also not, then it may be a loose antenna connection. WiFi and BT use the same antenna
Here's a teardown video that may help. The antenna can be seen passing down the right side of the battery at 4:18 minutes into the video, connecting from the top board to the bottom board.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 73
