Phone not turning on.
Hi! my iphone 7 recently got smashed and a curve is seen on the body. I removed the cover myself and found a connector cut. It looks like that connects the front camera and microphone.
please help me turn this thing on!
The board likely sustained heavy blunt force damage, there is no guarantee any of these are worth salvaging.
このアンサーは役に立ちましたか?
For starters,. You're going to need to have a look at this teardown guide you're going to have to make sure the logic board is not damaged, identify any other damaged parts and once you have the battery and most if not all parts out you can try bending the phone back. Since this is a common occurrence you can find multiple videos showing how to do that. Look at several before selecting a method... quality varies rather drastically. You can find needed parts here and more guides to specific fixes here if you run into problems along the way just ask for help with good closeup photos and descriptions. Good luck.
このアンサーは役に立ちましたか?
@tomchai is correct, the damage may not be fixable at a reasonable Cost.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 52
