grey spot on screen!
When i turn the phone , the grey spot makes it to white!
ALSO!! i had the same problem but in hours dissaperead! And overnight became this! PLS WELP GUYS!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi
Sorry to hear you are having a problem with your iPhone so let’s hear it fixed!
a mark on the screen can be a couple different things such as
Expanding battery
Water marked LCD
Water damage
Pressure marks
So chances are if you open your phone up and send us a photo of the inside we can help further
If this isn’t possible check to see if the battery is spongy or pillowy ,if neither you can replace the screen and it should fix the issue
このアンサーは役に立ちましたか?
Ty for answer! I tried to open my phone myself but i have 1 screw and its blocked cuz it hasnt been opebec in a while! if i could open it i would contact and send a picture! Thx!
Your welcome
If you have any more issue
Please do not hesitate to ask
Hello i maneged Otopeni my iPhone! It will be okay if i could contact you to send a picture to see what is the damage cause and if i could fix it myself ? Ty!
過去 24時間: 2
過去 7 日: 7
過去 30 日: 50
今までの合計 1,343
1件のコメント
Grey spot with darker edge is. 0 3 inch diameter... Can be moved around Android Chinese phone.. Can't open it or get rid of it off the screen.. Turning phone off on not affecting it..? IS THIS START OF CHINESE TAKE OVER... ALIENS...TAX MAN? OR MI6? OOOOERRR AI.?
Arfur mandom さんによる
