メインコンテンツにスキップ
How do I fix burnt capacitors near the battery point
I noticed a black ash near the charging point on the motherboard. I tried scrapping off the ash and found copper paper underneath. The laptop HDD runs and the MagSafe shows charging sign but the laptop doesn't boot. Pls help me out
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I suspect if you look Here you'll find helpful stuff.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
The first step is locating the board number so you can locate the schematics and boardview if they are available. What I often do is look at a logic board image for the given system, so in this case iFixit has a very good one MacBook Pro 15" (Model A1150) 2.16 GHz Logic Board. Now looking at the image we should find the board number which will either be etched within the traces (large ground plane segment) or printed on the board which is the case here 820-1993.
Now with that we can search online locating hopefully a free source for them. While you can find the schematics in PDF form for free. Sadly, you need a special app to view the boardview drawings which requires an old copy of Windows to run.
Even still you should be able to identify the component and maybe the markings will give you enough to get a replacement from a parts house.
Now the bad news... You''ll need to clean up the area to see if the traces are still intact as often times a burnt component damages the board. Rebuilding the traces might be possible, otherwise its time for a new logic board ;-{
MacBook Pro 15" (Model A1150) 2.16 GHz Logic Boardの画像
製品
$149.99
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
To read the boardview files you can download a free open source software for Windows and Mac OS : Openboardview
https://openboardview.org/
Good luck in your repair :-)
さんによる
@lemerise - Sadly, the older BV files are not readable with OpenBoardView unlike the BRD versions.
さんによる
コメントを追加
回答を追加する
Sourav SH さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 47
